J
Jack Klarich
Guest
I always thought nitrogen was for cars with the tire pressure monitoring system
Nope, it has proven to increase the life of the carcass of the tire, but IMO not worth the expense on a Motorcycle
Not for me as I do all my own tyre changing etc and have a good compressor or two that just do air although I do have a water trap on the outlet which will reduce the moisture content of the air
I've seen claims of 25% better tire wear,which, if true,would be worth it.I figured one a youse guys may have tried it to see.
I wonder if the better tire wear would be related to the tires holding pressure better? I do not dispute that nitrogen may hold some advantages over regular air, one of which is that it maintains better. I check my tire pressures each ride, but I would suspect a lot of people don't, and less than that on people who use nitrogen because they believe it would be less maintenance?
Any thoughts from the pros?
