5 & 6 speeds have No adjustments for the shift forks. Only the old 4 speeds did.
tourbox
Am I Wrong? Man that would be Only the umpteenth time:55:
I used to set the play between sides of the amount of Play and Position of the gear shifting (as one unit)
Putting shifter into 3 gear then adjust the Threaded bolt that was locked on the side of the tranny.
This adjustment allowed my gears to work properly on the shift up OR down.
I had a time when my 00 5 speed need this adjustment so it would shift into the next gear (sucked in) while down shifting...
NOW looking at the 6 speed I'd agree (no outside adjustment there, just a allen headed bolt) I actually had to go look at my 09 King, as I never had a Factory 6 speed before.
Oh well:dknow
Thanks for the correction tourbox BUT if you would please,
explain the side adjustment on the 5 speed if not for adjusting the fork bar positioning I did there.?
I Do remember making that adjustment on my 00 5 speed tranny.... ALSO,,,,when installing a rev tech 6 speed gear set into My 00 HD box...
Having a BIG problem trying to get that threaded bolt adjusted
Then Holding the adjustment made while tightening the lock nut... Tight place to work there for sure.
That adjustment allowed the fine-tuning I needed to shift the gears to make it work correctly...
Kinda like this example:
xxx-3-xx or xx-3-xxx
The 3 being 3rd gear and the adjuster screw moving the "x" location to allow one side or the other positioning adjustment.
Thanks
