free website stats program no key ignition removal 91 flhtc | Page 2 | Harley Davidson Forums
Here is the switch
1 608 ROLL PIN 1 0.99 0.49
2 909 SCREW 1 1.49 1.49
3 1601 SCREW 2 2.49 1.99
4 3581 SCREW 2 0.49 0.49
4A 4391 SCREW 2 1.49 0.99
5 6150W WASHER 1 0.99 0.49
6 6192 WASHER 4 1.99 1.49
7 7069 LOCKWASHER 10 0.99 0.49
8 7127 LOCKWASHER 2 1.99 1.99
9 7220 LOCKWASHER 2 0.99 0.49
10 7620W NUT 1 0.99 0.49
11 7638 NUT 11 0.99 0.49
12 7686 LOCKNUT 1 1.49 1.49
15 7688 LOCKNUT 4 1.49 0.99
16 7716 NUT 1 1.49 0.99
17 8498 RIVET 0.99 0.99
18 8536 RIVET 4
19 9952 CLIP, C.B. 3 6.49 5.99
20 10039 CABLE STRAP 1.49 0.99
21 31504-91 BRAKE LIGHT RELAY 1 9.49 8.49
21 31506-79B STARTER RELAY 1 11.00 9.99
22 33043-80 WASHER, NEUTRAL INDICATOR SWITCH 1 1.49 0.99
23 33900-59 SWITCH, NEUTRAL INDICATOR 1 30.00 27.00
24 45426-79 SLEEVE, FORK LOCK 1 6.99 5.99
25 45427-79 SHIELD, FORK LOCK 10.99 9.49
26 45437-81 LEVER ASSEMBLY, FORK LOCK #1 1 26.99 23.99
27 45447-81 SPRING 1 4.99 4.49
29 45494-79 SPRING, FORK LOCK 1 1.99 1.49
30 61077-82 KEYSET, IGNITION SWITCH & DOOR (SPECIFY KEY #.) 1
32 68537-89C TURN SIGNAL CANCELLER 1 150.49 135.49
33 71427-79A DECAL, IGNITION SWITCH 14.49 12.99
34 71517-86 SHIELD, FORK LOCK 1 40.00 36.00
35 71518-80 SCREW WITH WASHER 4 3.99 3.49
36 71526-80 HOUSING, IGNITION SWITCH 1 243.00 218.99
37 71536-82A KNOB, IGNITION SWITCH 1 244.00 219.99
38 71549-82A IGNITION SWITCH - W/ REF # 35, 36 & 37 1 93.00 83.99
39 72023-51A STOPLIGHT SWITCH, REAR 1 21.99 19.49
40 72300-89 FUSE, 1 AMP 2.99 2.49
40 72301-89 FUSE, 3 AMP 1.99 1.99
40 72302-89 FUSE, 5 AMP 1.99 1.99
41 72306-88 MOUNTING BRACKET 1 3.99 3.49
42 72316-89 FUSE BOARD 192.99 173.49
43 72320-89 MOUNTING PLATE 6.00 5.49
44 74589-73 CIRCUIT BREAKER 4 8.99 8.49
45 74599-77A CIRCUIT BREAKER, BATTERY 1 8.99 8.49
6182W WASHER (INTERNATIONAL ONLY) 1 1.49 0.99
6192 WASHER (INTERNATIONAL ONLY) 1 1.99 1.49
8483 RIVET (INTERNATIONAL ONLY) 1 0.49 0.49
8498 RIVET (INTERNATIONAL ONLY) 0.99 0.99
8536 RIVET (INTERNATIONAL ONLY) 1
9952 CLIP, C.B. (INTERNATIONAL ONLY) 1 6.49 5.99
31506-79B RELAY, PARKING LAMPS (INTERNATIONAL ONLY) 1 11.00 9.99
67858-89 SWITCH, PARKING LAMPS (INTERNATIONAL ONLY) 4.49 3.99
29 68384-91 TURN SIGNAL CANCELLER (INTERNATIONAL ONLY) 1 78.99 70.99
29 71512-89 SWITCH, PARKING LAMPS (INTERNATIONAL ONLY) 1 12.99 11.49
The problem is that a 91 has a different proceedure to remove the ignition lock. The reason I need to remove it is so I can get the lower/inner fairing off for an upgrade. I'm doing an electronics upgrade adding the newer fairings. any help would be appreciated.
