free website stats program No Lights! Help please! | Harley Davidson Forums
diver4life
Hi to all.
After a couple of miles riding yesterday my lights stopped working except for the signals and break light. Fuse is good, with the ignition on there is no current to the lights wires. Dont know if the problem could be the ignition switch or fuse box, any help from you guys will be appreciated.
Thanks.
Eliot.
Eliot, I hate electrical problems but I know a fast quick reliable solution.......Hoople! That guy knows his stuff. Like someone once said here, "everyone should have a Hoople in their toolbox".
Well, lets wait for Hoople then! thanks for your reply anyway. so far I know that there's no current going trough the lights wiring, I used a tester on the wires with the ignition switch in the on position. The thing is that I have no idea where to start looking for the problem.
I would check your switch. If memory serves me there are 3 wires on it. 1-power.1-ignition, 1-lights. When you turn the key on you should have power on all 3 lugs. The break light would still work even if lights didn't. Old days you had a separate switch position for lights, no day time lights on. Like was said Hoople will chime in soon hopefully.
tourbox
sounds like the ignition switch ... but first thing i would do is check all your grounds if there clean and tight . check the ingnition switch
Grounds are ok, I was thinking the same thing. I'm still going to wait for Hoople's input. Thanks .
Eliot.
tourbox
I will check for current before the switch and if there is something then I will remove the switch.
Thanks.
Eliot.
Can't hurt to check for voltage at the switch. Hoople will ask you. We have had a lot of switch problems here lately.
I'm no Hoople but could it be a short at the relay?
Thanks to all for the replies, tomorrow hopefully I will start testing again, I didnt have time today.
