Bub/Hoop/Chopper,
Thank you, I understand the plug shorting deal and will do that from now on.  Anyhow, stopped at my dealer on the way home from work and talked to my service manager.  He said that when they clear the lowers they really "HOG OUT" the material, they remove lots of material.  Well, they are going to clear out the lowers for me.  They've done hundreds in the past, I trust them, and have been VERY good to me.
As far as the low oil pressure....I may loosen up the 4 oil pump bolts, turn the motor over and after I put it back together (with new cleared lowers), see what happens.  Now, I did use the SE billet cam support plate and there was NOT an seal that goes between the oil pump and cam support plate.....did I miss something here?  Will it take time for the support plate and tappets to build pressure before sending oil up the pushrods?
I sure appreciate you guys time and advice.
