free website stats program No oil Pressure..Dummy light on.. | Page 3 | Harley Davidson Forums
Low oil pressure in an air cooled engine does two things, lack of lube for all internal parts and heat transfer, I agree with Bubbie and NEWHD get it checked NOW
Thanx for info guys, but I did take it in and dealership said it's normal on the roadglides when hot to drop at idle. I have a full extended warranty so they will replace it if it blows.
Good Luck and thank goodness for ESP Dont leave home with out it:s
Personally, I would still consider checking the oil pump alignment, seals and oil pressure regulator/relief valve...Baisley spring...?
Those with Twin Cam engines who have low pressure use this to resolve the problem...maybe something similar for your engine?
Baisley Hi-Performance Oil Spring Product
Don't like the idea of Zero pressure at idle, and only 30 PSI...but that is just me.
