I went to John Wadsworth (Herko) for my roller chain conversion kit. Great guy. I second Dolt's rec above.
I put the Andrews Products 21N grind cams in as replacements for OEM grind. Supposed to have more torque especially in the low rpm range which is what I wanted. The "21" or "26" grinds will probably do what you want. For the gear drive cams, the suffix it "G" (i.e., 21G or 26G). Check out this info:
Twin 88 Gear Drive Camshafts
I would also suggest getting new lifters and adjustable pushrods so you don't have to pull the rocker boxes.
