PetieJ
When you replace the lines in the tank, make sure they are the proper lines. The stock Harley lines will do or these maybe be better for wear and tear. There is a big difference in the quality and makeup between the two. Gates hoses are thicker walled. The Gates aren't as flexible as the Harley stock, but with the complete unit out of the tank, one can easily cut and form the hoses.
Gates 27093 5/16" Submersible Fuel Hose For In Tank Lines SAE 30R10
Submersible lines are fuel resistant on the inside and on the outside. A regular fuel line is fuel resistant just on the inside.
