dolt
Well-Known Member
Copper grease, good idea I guess but have never used it so can't comment. Sounds to me like the pistons are not retracting enough and are forcing the pads to remain in contact with the rotors as 89stroker experienced. Take the advice of fin_676 and clean the pistons, carefully as you don't want to push them completely out of the caliper.
Get a piece of 1/8" aluminum flat stock and insert it between the pads. Use the lever to force the pistons out to the aluminum stock. You will see the dirty vs clean part of the pistons. Soak a shoe lace in brake clean, get the shoe lace in there and clean each piston. Apply a little WD40 and the pistons will start retracting as they should to stop the pad drag on the rotor.:s
