I have experienced failure of the inner primary bearing and race in my 2007 FLTR. The race and rollers were severely spalled creating a grinding noise any time the clutch was turning (noise only stopped when bike stationary, clutch disengaged and trans in gear. No oil leak, but starter ring gear was hitting inner primary due to excessive clearance in failed bearing apparently letting clutch assy wobble around. I only have 60,000 miles on the bike and would like to find a higher capacity bearing and or inner race with better metalurgy so I don't have to go through this again before I die or get too old to ride. Does such an upgrade exist for this bearing ? In working up a parts list I found that in 2008 MoCo changed the transmission mainshaft and the inner race. However no change has been made for the roller part of the bearing installed in the inner primary.
Thanks for any info on this failure.
