BUBBIE
Well-Known Member
Just wanted to follow up and let you all know what I found.
- took the bike for a spin to warm everything up and then drained the primary.
- took off the primary cover and checked the compensator nut with a torque wrench at 65 foot pounds and it was tight. So that was not a problem.
- used brake cleaner on the clutch plates and inside the primary. cleaned up the mess and then used air compressor to clean it out further.
- adjusted the clutch while I had it apart.
- closed up the primary and refilled with 20w50 oil
- took the bike for ride, maybe 10 miles or so, everything was operating good.
- Got it back home and flushed out the oil one more time.
- filled it back up with 20w50 oil and will take it for a ride today.
I am pretty sure that I got primary flushed out pretty good, but think that I may empty out the fluids one more time after 100 miles or so.
IF you did that much clean-up, I doubt you will have problems.
Good job it sounds like. Hope you get Great rides in on your bike.
Thanks Jack for your Back-Up on the break-clean-spray. I have to admit, I only used it on brakes but I also Never put Red- ShockProof in the primary.:bigsmiley25:
You Da Man Jack.........
