bus driver
I forgot to answer your ? about Ign. on/off for the regulator test. The ign can be off because the reg. output wire to charge the battery goes to the Main 30 amp. breaker, then directly to the the starter post. It has the Pos. cable on it from the battery.
If your manual is the same as mine look at page 8-124 in the bottom R/H corner for the stator & reg. hook up.
tourbox
