Hoople
Account Removed
- rear bearings have had it at less that 6K.
That sure is a lot of work (belt tension, wheel alignment etc) to go through in just 6K miles.
The seals used on 6205 bearings were not designed to be the 1st line of attack in applications where they are exposed to sand and water hitting the hubs at possible high speeds. They are exposed to all the elements with no primary shield of any sort. The exposed wheel hub bearings really need a primary shield to separate the bearing from the "big stuff" first. The seals used on those bearings are just too fragile for the application.
I sure don't agree with how HD did it and think it's a bad idea. Don't think HD will ever go back to the taper bearings with real external weather resistant seals, but in time they will probably address it and put a patch on it..
