BUBBIE
Well-Known Member
Just wondering TQ, why no aviation fuel? I use to run my off road stuff on the 130 octane avgas and they ran great.
High compression = need for High octane (slower burning)
Too high octane will Not develop the power needed to run a Low compression (normal) motor...
85 octane has More BTU's than 92 octane, thus more power in lower octane..
Octane is used to Slow and Even the burn rate of the fuel.. It helps by Not allowing early Pre-ignition and from exploding under compression.... Fuel needs to Burn evenly, not blowing up and damaging the piston-crank by trying to run engine backwards...
95 would be a good stopping place on the Ron system of measurement..
91 will do the job on these HD engines Unless you have Higher than stock compression...
Hot days and Hot motor temperatures do cause our engines to have the need for MORE octane than normal cool conditions do... This is why some will hear a little rattle then and think it to be bad gas when it is not... Just a lot of High temps.
