markfsanderson
The Jack looks ok apart from one concern that i have for the dyna although my experience is with evo dyna's
the side stand on my dyna is attached slightly left of centre under the bike and you may find that the cross bar on the jack may foul the side stand or the spring although it may just be clear
there is a set of jack adaptors available from HD for the dyna frames so that the oil tank does not foul on the jack
Twin Cam - Equipped Dyna Model Motorcycle Service Lift Adapter Kit | Genuine Motor Accessories | Harley-Davidson USA
Brian,
This is interesting . . . hmm . . . so the metal brackets that connect the the two pieces that directly contact the bike might be set so that it possibly interferes with the jackstand? So if this crossmember is set low, it probably would be a problem . . .but it if it is at the same level as the load supporting memebers - it might screw them up? I can always return it if it looks like it'll damage the kick stand . . . they have a 30 day no hassle return policy . . .
Thanks for the info!
Mark - Thanks!
