silentflyer
Anyone have a picture? Can't get the link to open. Thx
Sheepdogmarin/Glider
I have a drawing of how I routed the blow by oil tubing up to get it all in the intake. I received your private message and would love to reply, by I don't know how to. I want to send an e-mail with attached drawing. Help.
Mac
Okay, Sheepdogmarine, I think I can give you a link now so you can pull up the drawing. Still don't know how to send it in a pm. Try, [removed] . Hope you get the drawing and that it'll help you see what I did.
Okay Sheepdogmarine, I just tried it and I could hardly make it out, so it will not help you. You must have a stage 1 installed that uses a K&N air filter. You can't do what I did with a stock air cleaner'. Very simple set up w/stage one. Just remove the cover and filter element and find the inlet through the air breather mounting plate where black rubber hose is attached and put a piece of 1/4" tubing in that hole and have it bent around so that it is aimed at the intake. Bend it so as the filter will fit down over it. Make sure the tubing is well attached into the fitting so that is doesn't come loose and jam the slide or get sucked into the intake. Hope this helps.
