BUBBIE
Well-Known Member
Bubbie,Are you refering to the top cover on trans that is held on with 6 bolts?He is still having issues he did get back home and at 80 mph is still putting engine oil into trans then out thru the vent.by taking the air cleaner off it helped (i know should not run it that way either) at least he was able to get it home but it still blows out the trans vent tube.
Yes, the cover on top of the tyranny IS connected via the oil filler neck Just Gaskets separate them from mixing product..
I feel it is a Over-pressured engine that is blowing oil via the ?? gasket or Tube vent and it is like some say a Ring blow-by problem.....(at 80)
I'm ONLY guessing and it does seem possible that is the problem...
The Tyranny will always get rid of Over Full condition by blowing it out the tube and at 80miles per hour, on bad ring seals you would get a LOT of pressure (hard blowing oil)into the return oil..
