mystryman
I'll check that out while I'm waiting on the parts I ordered. Although the oem gear had not jumped and appeared ok, I had already ordered the steel one and intend to put it in anyway. might not get to it today though, I have other things on the agenda I need to do.
I'm also thinking of an idea of putting a pressure relief hose on the oil filler housing. Had read elsewhere on someone that did this and supposedly there's a company that sells kits like it. It doesn't fix the root cause of the problem but maybe it keep it from happening again if all else fails.
took a look into the check valve and pressure valve on the oil pump yesterday. they're good, no problems. not gummed up or anything.
