Hey Breeze, no, I removed the big ~6" dia round clutch inspection cover plate - and NO I still can not see anything pertaining to the oil leves as shown in the book. Let me attempt to describe - with the cover plate removed, the cluth plates and rings etc (not sure what to call all the stuff inside) is only about 1/4" from touching the primary cover - and down inside about 1" or so below the opening, is the oil level per the pictures. At best, very difficult to see and judge the levels. I have a 2001 Heritage and actually, I have not removed the smaller rectangle looking window in the middle of the primary cover. I need to take it off in order to inspect the chain tensioner and free play.Bilbo; From your discription in post #8, I think you removed your primary inspection cover(oval, in the middle of the primary) not the derby (big round at the back of primary). With the derby cover off, all you can see is the clutch pack, may need a flashlight to illuminate the oil level. I know you have a serv. manual, and the '01 may be different, but we usually get 38oz. out of the primary when changing. Where did you see 26 oz. called out? I use teflon tape, only because that's what I have on hand, don't put it past the end that sticks in the case. I don't have a Softail, so I'm gonna leave the plug tightning / distance alone.
Thanks for your response and help here, I should probably use some teflon tape or permatex liquid teflon on the plugs. I am still gonna replace all the o-rings.
Bill
Breeze, also, my owners manual and service manual for the 2001 indicate :Bilbo; From your discription in post #8, I think you removed your primary inspection cover(oval, in the middle of the primary) not the derby (big round at the back of primary). With the derby cover off, all you can see is the clutch pack, may need a flashlight to illuminate the oil level. I know you have a serv. manual, and the '01 may be different, but we usually get 38oz. out of the primary when changing. Where did you see 26 oz. called out? I use teflon tape, only because that's what I have on hand, don't put it past the end that sticks in the case. I don't have a Softail, so I'm gonna leave the plug tightning / distance alone.
Primary capacity - 26 ounces
Engine capacity - 3.5 qts
Transmission capacity - 24 ounces
I know the dealer put in a full qt in the primary - it's supposed to have 26 ozs. and some here have said too much may make shifting harder and finding neutral more difficult.???
thanks again,
Bill
