This actually brings up a Question I had but can not find the answer to. Maybe others have experienced the same. I have only tried this one time.
If I get my engine hot, then let it sit for 15 minutes and remove the oil filter, the oil in the filter runs out all over the place as you would expect.
But if I let the bike sit for a couple of days, and remove the oil filter from a stone cold un-started engine, the filter will be completely empty. Not a drop of oil will come out.
I researched to see if there is some kind of check valve or 1 way valve to prevent oil from draining out of the filter but could not find anything about it.
I have seen where some oil check valves was actually in the filter itself but don't know if that is the case with HD filters.
Funny thing is, whenever I start the bike (even after days of non use), the oil light does go immediately off.
I don't like the idea that my filter needs to refill if the bike has been sitting for a couple of days.
Would anyone know if a check valve does exist. And if so where is it located.
