This is a strange problem to have since the tranny in a HD is a splash/slung oil system, not a pressurized system.
Your book probably says that the tranny holds 20-24oz. of fluid. If you are doing a wet oil change (not opening up the tranny and completely drying it), you will likely need less than the full 24 oz. to refill it. Even if you got 23 oz. out of the tranny, I would start off adding back 20 oz., ride the bike a bit and then measure the fluid on the stick with the bike completely up-right and level. Add more fluid as required to be "Full".
When you say that the oil formed a small puddle under the bike, how much do you think that was? A little bit goes a long way with this stuff.
Finally, if you are still using that silly little "J" tube as the vent line, I suggest going to O'Reillys or AutoZone and getting a few feet of hose that will fit on that 90* nipple coming out of the tranny cover. Route the hose up over the other side of the tranny and down under the bike over by the fuel overflow line. I bet that solves it!!
Primary Oil Leak - Harley Davidson Community
