Hoople
Account Removed
The dealer installed/turned on the heat management system.
Now when your at a stop light and the bike starts to idle like it has radical cams, you will know what to do!
if it was annoying he would give me one free "shut off",
The service tech explained the prerequisites to have the heat management system come on and how/what would reset the system. He told me to try it for a while and if it was annoying he would give me one free "shut off", since the system should have been enabled. I will give it a whirl. I am intersted to see when the system kicks in vs. my perception of how hot the motor is.![]()
Hoople I suspect the EITMS you are referring to is the heat mode where the rear cylinder stops firing and just pumps air.
Yes, it stops firing.
My Dyna firmware does not have stages. All at once, rear cylinder stops and engine runs rich.
I would have liked to look at your Lenale Fan when you were in Daytona. That write up was a Great read. No doubt it does work. I wanted to purchase one and contacted Lenale about how long warranty was because I heard of several having bearing problems in under 1 year of use.
My first lenale fan burnt up I mean it caught fire.
Was late 07. The replacement they sent me has had no problems. I removed it from my 07 when I traded it and it is going on the bike.
YES on 07's it had to be done by the dealer your were offer the chance to try it and if you wanted it turned off they would do it one time for free
Fans are certainly good and will help but if you get the AFR's correct, you won't necessarily need a fan to help cool your motor unless your riding in outside temperatures over 105 degrees,
