If you are going to run in 80-100degee ambiant temperature and you like your bike,I think the cooler is necessary,if it cools it 10degrees that is 40 degrees at the crank,It is impossible for it to lower pressure,unless it is so low on oil that there is air going through the oil pump.The motor oil I like is Mobil I V-Twin,
