TripleJ
Senior Member
The reason for leaving that one alone is it is installed with red locktight and could possibly crack the engine case while trying to remove it. If you loosened it up and retightened it and it does not leak you should be good to go.
I would keep an eye on it to see if a leak develops later. The service manual will be the best money spent on your scoot, good move.
