The oil filter laying on its side will drain out from center down into engine, the rest of oil thats around (outside) of the filter will seep thru and some will also go into engine. The nature of the beast.
20W50 oil flows like 20wt oil at a measured temp standard, as oil heats up, polymers expand to form oil film like 50wt oil. Engine oil at standard temp will flow,have shear capacity and react like 50wt oil, even though it appears thin.
To me if oil pump is good, not much oil will go backwards thru pump from oil filter.
Also, cold temps do weird things to machines. Start'er up and let idle a couple of minutes longer to let oil get fully circulated and alittle warmed up first before riding bike.
wilks3
wilks3
