89 FXRS
I noticed my oil pressure doing that too. At start up (cold) pressure would be 34 at idle. After riding for a while when oil is hot the pressure would drop down to between 5 and 10. But at 2000 to 2500 rpm's it will go back to 34. It freaked me out at first, but I have been reading a lot on the internet from other sites that this is normal?
From everything I've read and seen yes it is normal to show little to nothing at idle/ when warmed up 34psi is also normal at 2000rpm and above - the factory manual states that @2000rpm+ it should be 30-38psi.
Why would you go to all that trouble?We have used mechanical guages on the race cars for the last 25 yrs. and just route clear high pressure plastic hose from the sending unit to where we want to mount the guage.
I wanted to eliminate the sending unit so I could know if the problem was the gauge or the sending unit, it wasn't much trouble at all, just replaced the sending unit with a piece of tapered threaded pipe and did basically what you did.
