BUBBIE
Well-Known Member
Thanks
What year bike is this on..... I am confused on that bike you are working on or own.. The Newer cam-plate IS done differently on Different Year HD's. Some OLDER HD's Require a PLUG to be installed in the new cam-plate or the oil Goes pumping (wildly) into the crankcase and Not enough oil pressure at IDLE IS a problem..
Not on the newer bikes though... IF your working on a 00 - 01 - 02 - 03 , Not sure when this design change on the mating surface of the engine oil system changed but it did for the Newer Later Bikes..
Just something to check as I, AM Trying to understand.....
DO you get the oil pressure BACK and NOISE Goes AWAY IF You Raise the IDLE to 2000 RPM? After the reading of "0" oil pressure and engine Noisy.
THIS tells ME it is only LOW at IDLE position....
This IS important to know......... DOES the pressure come back up...
IF it does, this Gives more credence to the needed "plug-off" of an oil hole on the cam-plate.
OR-------
Sticking OPEN on the cam-plate PR Valve slide could still be the problem...
IF Open at idle and when you raise the idle to 2000 and oil comes back,,,, You see ? Tough one to find the correct answer for the problem...
RE-Read my post #12
