Fisherking
On my 02 Fatboy i have never seen the temp get over 220.
I run Mobil 1 20-50 full synthetic.
F.K.
F.K.
I also have a Fatboy Lo,last year when I bought it and ran it for 1st 1000 miles the temp would get up to 220 max on the normal oil. I switched to full synthetic and the temp is around 200-210 in 90 degree weather, but it usually runs anywhere from 180(winter) to 210(summer) but it depends on the traffic, weather (windy days it always cooler), etc... I bought one of those analog thermometers dipsticks and can glance down while sitting at a redlight and see what the temp is. If you dont have one I highly recommend it. I asked my dealer if I should get an oil cooler and he said he doesnt use one, and so far the temp hasnt spiked enough to scare me yet into buying a cooler and I ride almost everyday to work on it. Plus my legs tell me when the engine is getting hot :newsmile014: Thinking about a shield for the heat. I Hope this helps you!
My 08 Softail - completely stock - on analog oil gauge in the oil tank, I get readings of around 230-240 in the city with the usual stop & go driving. The ambient temps are about 90 F at the time.
A lean condition caused by an intake leak can cause higher temps. Engine mods done without a tuner or ECU downloads can give you a lean setup.
