llharr
Silicon can be an additive in the oil to start with, but if the oil didn't have it to start with, the main source for finding silicon in a sample (on an air cooled engine) would be from ingested sand.
On water-cooled engines with antifreeze, coolant getting into the oil would be a source.
I am sending in an unused sample of oil to get a baseline measurement. It's possible that the oil & additive I use contains a high amount to start with. That would be ok. But if my baseline is 2 PPM and the other 12 PPM are coming from sand & dirt through my air cleaner, that needs to be fixed.
I'm sure you know what happens if left uncorrected..![]()
Hoople, I think you have open up a new can of worms here! I myself also run a K&N air filter that in the back of my mind often wonder if it would filter 100% of contaminants. I have cleaned and reoiled the K&N air filter and held it up to the sunlight and could see tiny holes in the filter itself, thinking some contaminants could get pass the air filter. Also I could see what looked dirt in the throat of the air intake. I know a lot of bikers run the K&N air filter because of more air flow. But if it lets sand particles thru then I don't need it!
