well if you really need additional indicators then what you have to do is pull out the headlight, locate the turn signal power wires in the harness, there are three wire to the left and three wires to the right. find the one that powers up when the signal flashes, now solder on and wire to this and run it up to where ever you want your indicator. solder a 570 ohm resistor to the wire, solder the other end of the resistor to an leds cathode terminal (this is the longer leg if you have a new led), then ground the other side of the led. wiring is the easy part-making a pretty mount is the hard part.
the v logo is designed for the 07 and older, the 08 rk has the plastic insert right where the v logo would mount. maybe you could drill into the trim cover and put leds in there.
