J
Jack Klarich
Guest
It would work the same as the cable..
On my Dads 51, the rod adjustment was done so it would fully disengage and Maybe yours is too Loose of an adjustment?
The suicide clutch should totally move enough to release the plates... DID it work before adjustment?
One reason I always want to see and remember Where the original adjustment was Before I Rework the clutch adjustment..
ALSO,,,, where are you getting the information to adjust the clutch???
Hope you are Not using the modern bike adjustment here....
Bubbie, it looks like he used the self help video for newer clutches, this will not work on the old dry clutches
