Redfish-Joe
Senior Member
Tim,, In more ways than one.
Took me a minute to pick up on that Hoople.
If you have the part number, you can almost always beat your dealer's price by checking out Zanotti's:
Harley-Davidson Bikes - ZANOTTI MOTOR CO. INC, Butler, PA 16001 -
Then you need to determine if you have the expertise, tools, and manual to do the job yourself. If not, it may be better to get the whole thing (parts and labor) through the dealer of your choice.
I ended up in the US 400 region for the rotor and stator. Supplied my own ass'y lube and elbow grease to get it all sorted.
Actually, this dealer seems to have a reasonable parts policy for real parts (i.e. internal stuff), while shiny and go fast stuff is VERY expensive (up to 3 times US prices).
As you can imagine, I do not buy my go fast&shiny parts from them, but import directly from the US - normally Zanotti's, H&M or M&M Cycles (sometimes eBay) and save up to 50% off the dealer prices - including shipping & import tax!
How is your investigations going, btw, have you taken off the primary yet?
Inquiring minds want to know...
I just had the comp nut coming loose, causing havoc in the primary:
The rotor splines were sheared off, but the shaft splines were good as new (supporting Tim's claims).
I assume BTW you were looking at the rotor from the chain adjustment cover, not the derby cover? Never tried that, but it should be doable.
One thing you do not know, is if the stator is toast as well. The hole in my rotor was oval, and the thing had worn down /cut off several stator magnets and part of the lip in the case that holds the sealing O-ring in place.
You can imagine the sight when I opened the primary - I had aluminium bits, steel bits, and magnet bits everywhere - a right mess. The clutch ass'y was luckily ok...
What I did next, is only doable on a Harley (possibly old Brit iron as well):
I carefully cleaned out ALL pieces, installed new stator and rotor, cluch basket ass'y, chain and comp nut, primary, filled with oil, and she is good to go - unbelievable!
Bottom line: Open the primary before ordering parts (from Zanotti's)
Why not take some of that saved dough and hit the donate button? Glad your on the way to being in the wind again.
