free website stats program Plugs Fowling | Page 2 | Harley Davidson Forums
Plugs Fowling
I've always been taught that orange is not enough power, and white is too much. The spark should be a blue in color.
Im going to check tommorow morning when I get off work, but if it is a weak spark then what. does that mean a weak coil. Also when replacing my points, i noticed that the Cam end was a little loose fitting. I wouldnt think that would cause a weak spark, which is what I believe the problem is right now. It might causea timing issue, but the bike runs great for a little while with new plugs.
So I checked my spark with a screw driver in the plug wire. It has a very little orange spark. However the spark is consistant. I was thinking maybe the coil, but I thought they were either bad or good. Today I am going to rerun the wire from the points to the coil to see if that has any effect.
