Quote:
Originally Posted by ahern25
and when the cap opens I hear air release as if I was opening a coke bottle.
Hooples quote
Are you sure about that. I can not imagine that would be the case.
__________________
While all else fails, hit the entabulator button.
ahern25,
IF you have pressure in this part of the oil system it should Not to be there..
This part of the Oil system is Not pressurized Nor would/should it be.. Free flowing to where the sump oil is picked up and Pumped back to the oil tank . No pressure should be in the oil tank.
Taking off the oil cap No noise or Pressure should be there.
Have the heads and cyl. been off and Maybe the gaskets are not on right and allowing pressure to build up???,,,
Lots of blow by would also could cause the "Air" problem and with oil out the breather but not staying long enough to Hear "Air" escape thru the oil tank filler.
I could see the oil pumped back INTO the oil tank causing pressure IF::::::
The oil tank is vented thru the tranny vent tube and no pressure UNLES that tube is plugged... Check It Please..... Hmmmmmm
