mtaylor1111
Mtaylor, has anyone checked to see if your map needs adjusting?
Swyped from my Evo 4G using Tapatalk
We tried several maps including a zero map. Appears to be a defective PC III
DynoJet now has my PC III hope it comes back working. Really would like to see it on my bike.
DynoJet said they tested it and sent it back. I'm still having problems. Install PC III on bike and it stalls,
Based on what you said earlier (entry point #14), thought you already went down that road of sending it off to them. Feels more like a "loop" than a thread.
Had the same problem found out the settings were too rich at throttle postion 0% between 500 and 2500 rpm so i hook up the laptop and let the bike get hot and the put in values 10% less than is shown Mine showed 13 so i typed in 3 then pushed the insert key i did this at all 0% line from 500 to 2500 rpm i took care of my stalling problem I hope this helps
