Lowrider85
For small increases in compression I would deck the heads. If you want higher compression, i.e. 10 to 1 or greater I would change to high compression pistons.
Tell them what you want and I'm sure they can recommend something....
It all depends on what you want, how streetable (reliable) you want it and how much you want to spend. Cash is KING when it comes to power....
OH YEAH!!!! Don't forget your carb!!!!!! (unless you're injected) I'm running an S&S Super G with a thunderjet. If you're injected, get a good high performance tunable module. Do your just research and I'm sure you'll be happy.
