Well- - - This is really nuts! I checked the cases for cracks- - none
The bolts are the same length- - - I torqued them according to the shop book- - and in sequence. Sealant was applied- - - new lock tabs- - - checked for leakage from other sources- - none. Put a filter on the breather just to see if it would get soaked- - nope.
Yup----darn thing is like an old dog----leaves a puddle.
After I had r/r the thing a couple of days ago, I let it sit to cure the sealant. Yesterday I went for a ride and lo and behold, when I parked in the garage and came back- - -
IT IS LEAKING!!
Checked with other guys in my area last night and they have no ideas other than take it to HD and spend several hundred bucks. My God, I can build T-Buckets and 500 HP small block chevy engines and I can't figure this one out? Ahhhhh- - - - - -
So it will come apart today and I will check the bolt holes for debris and put another set of seals into the casing. Wish me luck?
Jon
IT IS LEAKING!!
Jon
