have you never seen someone gas weld a leak in a full fuel tank on the car, no problem if you are brave thats how they used to fixem before a few that didn`t know what they were doing caught fire and compensation set rules for repair.tom
the harley manual says its okay to use an impact to take it off but to use a torque wrench going back on. Engine nut is torqued to 150 to 165 ft lb. The clutch hub nut to 70 to 80 ft lb. thats is on late model Evo. I doubt the specs would be much different than TC88.I used a impact on my 06 Dyna with no problem and you can replace the chain on the 06 + newer without removing the clutch basket. tom
Don`t think you are the only one to do that... I did the same thing about 15 years ago. Removed the remaining part of the nut with a die grinder and cutting wheel. One thing for certain, you will never have to refer to the manual to see which way to turn the compensator nut to loosen it...
I have been struggling to get the compensator nut loose on mine, any tips?
