dolt
Well-Known Member
I for sure want to change the tensioner.
Ran across this simple and economical fix and thought I would pass it on; same as welding the OEM hydro tensioner but with a mechanical fastener. On a softail, this mod can be made in place but on a bagger, the primary is too thick so you would have to set the tension, mark the tensioner, take it off, bolt it up and reinstall. Check the pics for a better explanation. Use a button head bolt as used in the photo.
