2006FXDCI
Thanks Glider, it's been draining since last night. I am going to pull outer primary and wipe everything down as good as I can then start it up. I wasn't sure if running it with no oil would hurt my stator or burn up the oil seal in the inner primary. Have you ever used a grinder to remove the case material so you can pull off the rotor ? I wanna check and see if the bolts holding my stator in have backed out and are rubbing the rotor.
