SpringerSteve98
I get a leak coming out of my overflow into my air breather when i run over 2k miles without an oil filter change. Usually changing my oil filter will cure the problem. I think what happens here is the oil filter gets clogged a bit, then creates a higher oil pressure and causes oil to run out my overflow (which convieniently runs into my air filter). But in response to your question - Its possible putting an air filter with higher flow might help the overflow a little. The only reason i say this is because where the oil vent ends up is actually inside your air filter. I'm assuming theres a bit of vacume in there (sucking on the end of the overflow) while the bike is running. So logically, having a higher flow air filter would decrease the amount of vacume pressure inside the air filter assembly (where your overflow ends up). I don't know thats its going to make that much of a difference, but mabye some. When mine starts puking oil thru the overflow i put a fresh oil filter and fresh oil in it... It helps.
OK, looking back over your question... Your primary is on the left side of your engine. Usually the pipes are on the right side? This leads me to believe its coming from your air breather instead of your primary.
I have a leak coming from that general area also behind the inner primary ('01 FLHRC). Really only noticable after riding and the oil has sprayed over my rear pipe and the ol' lady's pants leg. When it sits afterward it only drops a spot the size of a quarter.
