Check Lubricant Level
1. Ride motorcycle until engine is warmed up to normal
operating temperature.
2. Stand motorcycle upright, so that primary chaincase is
level.
3. See Figure 1-12. Remove five screws to free clutch
inspection cover from primary chaincase cover.
4. Remove seal ring from clutch inspection cover and discard.
5. If the fluid level can be seen, it is adequate. Otherwise,
pour enough GENUINE Harley-Davidson FORMULA+
TRANSMISSION AND PRIMARY CHAINCASE LUBRICANT
(Part No. 99851-05, U.S. quart) in through the
clutch inspection cover opening until it is visible along the
bottom portion of the clutch assembly.
6. Refer to Changing Chaincase Lubricant
When draining or adding lubricant, do not allow dirt, debris
or other contaminants to enter the engine. (00198a)
2. Remove five screws to free clutch inspection cover from
3. Remove drain plug at bottom of primary chaincase. Drain
lubricant into suitable container.
NOTE
Dispose of chaincase lubricant in accordance with local regulations.
4. Clean drain plug magnet. If plug has accumulated a lot of
debris, inspect the condition of chaincase components.
5. Inspect drain plug O-ring for cuts, tears or signs of deterioration.
Replace as necessary.
6. Install drain plug into primary chaincase and tighten to 14-
21 ft-lbs (19.0-28.5 Nm).
7. Pour 38 fl. oz. (1124 ml) of GENUINE Harley-Davidson
FORMULA+ TRANSMISSION AND PRIMARY CHAINCASE
LUBRICANT (Part No. 99851-05 quart) through the
clutch inspection cover opening.
NOTE
Only add 45 fl. oz. (1331 ml) after service that involves removal
