ultra rider 05
Replaced my air shocks with 430's the ride is so much better and very easy to adjust.
...considering changing out the rear shocks on my '01 RKC to a set of "standard duty" 412's. I ride solo 99% of the time, and dont really need the adjustability of air shocks, but would be nice to dial in the pre-load & leave it there. Just looking for a firm, comfortable ride, without messing with air pressures....any input/comments would be helpful
thanks for the info...was originally leaning towards the HD's, but then reading too many "I shoulda bought the standard duty" threads, I changed my mind. I do like my suspension on the "firmer" side, and weigh about 220 lbs myself, so the HD's may not be a bad idea, especially on the ol' 750 lb rkcI would go with the Heavy spring on the 412s...The standard is a little soft for a bagger even solo...I know a couple guys that have tried 412s with standard springs and ended up having to switch to the heavy spring....They are very happy with the 412 heavy spring...The 440s you can get away with standard springs even two up.
Thanks for the link. Is there anyway I can test my airshocks to see if I busted the seal. I would have thought I would see oil leaking out but they are clean. Thanks again.
