The stud is removeable by double nutting it to back out, with the slight possibility of snapping it off in the head (just to give you more to worry about). When removed, you could use an allen head bolt in that spot.
Thanks Pete, I had mine out before that's why I floated the idea.
Concentrate here. So, you didn't replace the exhaust gasket? That may be your only problem. Get you a new OEM gasket and try again. Concentrate.. Dont get in a hurry! The HD exhaust to head gasket is the most forgiving.
As far as putting a small dimple in the header to gain more room is possible. I once had the same problem on a race car and I ever so lightly put a small dimple with a hammer and it worked. A small dimple should not cause any exhaust flow issues.
Here's a picture of the nut right up against the header. Rear header pipe at the top, cylinder head to the right, crossover pipe in the background. The viewing angle is from the right side of the bike looking up a bit from the area of the base of the cylinder right where the pushrod tube is.
Dr. D,
Someone may have already asked this, but if you remove the heat shield, do you have the room you need to get a 1/4" drive socket and extension (6") in there to the head nut? I have always done it that way, and can't imagine HD making that big a change in the design. They have to get on these nuts too.
Cheers,
If you loosen the heat shield you can rotate it enough to give you more room to get on that nut with a 1/4 drive socket:s
I hate to break it to you gentleman but the heat shields are already off! I'm starting to think that my bike was assembled with a head pipe that was just slightly out of specs - just enough to defeat getting a socket on this nut. This would explain why that nut was only finger tight when I took it off.
