ALLOW FULL TIME TO BLEED Before you start motor......:naughty
And BETWEEN adjusting each push rod too or you will bend things up nicely.
I have the SE adjustable push rods (they are not tapered) and I set them to 3 turns and there is alot of noise from the top end. I took off the rear rocker box cover to see how much oil is getting up there and it doesn't seem to be very much. The gage shows 36 psi at 1500rpm and above and I'm using HD 50W oil. What am I doing wrong. (Also replaced the lifters with new stock ones just in case that was the problem. But it wasn't.) I sure would like to get rid of that irritating noise.
82K miles and I did check the side play in the rocker arms and they are right at .010. I wonder if I could put a shim in there to reduce that spacing and see if that works. I just did a top end overhaul, I should have done it then.
