You are correct, the cam, cam plate, lifters and pushrods do not have to be removed.
Make sure to remove plugs and rotate rear tire in 5th or 6th gear.
tourbox;If you think about it, with the gears/sprockets removed from the front of the cam support plate then there is nothing to turn the cams over. They are driven by the gear/sprocket on the pinion shaft to the rear cam by the chain you removed. Your valve clearance is already there.
tourbox
In other posts he's talking about his 07 Road KIng Classic.What year bike is this that has .001?
