R
Ricks2524
Guest
Rick, did you connect the LGN/V wire from the tach to the Tach Output, pin #3, of the ECM? That is an unused pin. Try connecting to pin #5, Serial Data Link. The wiring diagram for the '07 Dyna shows the tach connected this way, and the wire maintains the same color code all the way.
If things still don't work, tell us what you connected each wire to. Specifics always help.
You might want to ask Admin to move this thread over to the one you initially started, for continuity.
