I figured out my problem. Bad ball bearings on the front of my cams. Luckily I pulled the cam before damage was done. I have the year bike that Harley used low quality ball bearings on the front side of the cams (1999, my bike is listed as 2000, but engine was made in 1999). Harley later, 2000, installed roller bearings in the front cam/cam plates to fix the problem. I walked in a motor cycle shop with my cams still in the cam plate and the mechanic said, "I've fix 500 of these!. You have to be the last one with those bearing!"
If I had known to search for 1999 cam bearing problem instead of year 2000, I would have solved this mystery long time ago. So, I ordered the 26N Andrews cam kit that includes the gear driven cam sprockets. No chain tensioners or chains anymore.
The thread that helped me was by glider, thanks glider!
I can't post the link to gliders thread, but search for cam bearing problem
LUCKY IT DIDN"T BLOW!!!
WHILE YOU ARE THERE.......
You might want to do another NEEDED job in THAT engine WHILE YOU ARE THERE....
MY 2000 dyna (same as yours 1999 early) I caught mine before any BEARING problems....converted over to GEAR DRIVE because of CHIPS off tensioners.... foaming oil and crank running in TOO MUCH OIL (not returning fast enough out of sump)
THIS (your) oil pump was not the best designed and had a lot of problems (sumping oil) not getting enough oil removed in large enough quanities causing foaming of oil and dumping out the air cleaner .....
the OIL PUMP SHOULD be replaced to a newer style ... and cam support plate upgrade .... HD has a GOOD replacement NOW
in the 06 dyna and 96" 07's on up,,, they change to aBIGGER n BETTER pump - cam support plate along with a new chain and tensioner system....
MY OPINION is poor engineering on the earler oil pump.......
I went with feuling $$$ oil pump and delkron $$$ support plate...GLAD I DID!!!!!
I totally rebuilt MY motor using above pump and plate with 570 SS gear drive cams, 10.25/1 scrm'n eagle big bore pistons and jugs, manley valves n springs, flowed heads... 42 mikuni , larger intake manifold, a race tuner: scrm'n eagle programable... 6 speed gears into tranny and put on a respectable 117,000 on bike (still looks new) and 48,000 mi. on the engine rebuild....
(I use all REDLINE synthetics)
20/50 in engine..MTL in primary ...SHOCKPROOF HEAVY in tranny...
RAN great... I finally traded for a NEW FLHR
I will NOT change a thing on my 09 FLHR cause of it's BETTER DESIGN!
ON YOURS,I would at least do the OIL PUMP.... harley has a pump that should of been USED in the first place (larger) and would do good on your 2000 twin cam...
On the problem with the cam bearings...(yours going out)
HARLEY WOULD OF DONE THE FIX ALL FOR FREE..... doesn't matter WHO owned the bike nor how many miles or times it was bought n sold....
BELIEVE ME I KNOW THIS TO BE THE CASE..... They had MANY people MAD about HD saying"""" we will only fix it when it is a problem"""" ....Your's finally became a PROBLEM and could of been fixed for free......
YOU COULD OF taken it to a dealer for the FREE repair(them tearing it down)..... but you would have it JUST STOCK,, with the larger ROLLER bearing instead of the ball style and the INNER cam bearings stock which should be CHANGED also....... (to "full" style rollers)
Glad I went to the gear drive on that model year... YOU should have NO problem like the NEWER bikes do with excessive crank run-out...The cranks were BETTER in the early twin cams.... SAID GLIDER TO ME LONG AGO......
