Bought an 07 FLHR, and will be changing to Syn oils; first AMSOIL 20W50 MCV for the engine. I’d like to drain most/all of the old oil, at least this time, without the RC scavenger kit. From reading the many posts here, seems bumping might do the job. Other techniques?
If bumping is spinning the engine with the starter motor, then it seems it would help to remove the spark plugs. Should the plugs be left on the cables and grounded, or does it matter?
Should this be done with the old filter still installed, or with the new filter (using the HD 5 micron filter)? From a flow viewpoint, for the 96ci engines, is the filter on the feed side to the motor (oil tank -> filter -> motor) or on the return side (motor->filter->oil tank)?
Being new to Harleys, I’ve found invaluable information on this forum, and will be forever grateful for the knowledge being shared. Thank you all.
