Hoople
Account Removed
I think we missed the part about the conversion kit?
So the kit comes with a new cam plate... maybe gear drive?
Look at the camplate end of these cams, they have a larger diameter bearing surface that is designed to ride in the cam plate w/o bearings that is why the 07 camplate is required. The inboard end of the cams retains teh original size and utilize the original bearings.A friend converted his '04 or '05,can't remember the year,to the new upgrade support plate/oil pump/tensioner kit.The bearings still had to be pressed into the cam support plate.
He borrowed my tools & time to do it. On '07 and later the inner bearing changed diameter and outer bearings eliminated with bushing/machined area
tourbox
Important Product Notes
Stock H-D parts needed (from an H-D dealer): 2007 cam support plate; 2007 or later oil pump, cam sprockets and chains, and both hydraulic chain adjusters.
The new oil pump does nothing over my old that I can tell. 32lbs @2000 rpms and 37 @3000. At running temp on 85 degree day it ran about 18 lbs at idle.
Nothing better than my original, in fact exactly the same.
